964 Forum 1989-1994
broken coil wire conector
Old Jul 14, 2006 | 02:01 AM
doug751's Avatar
doug751
Default broken coil wire conector
I replaced my coils and distributor caps and rotors. We reassembling, I broke one of the connectors on the #II coil wire.
How do I buy only the one cable, not a set?
Thanks!
-Doug
Old Jul 14, 2006 | 04:27 AM
Computamedic's Avatar
Computamedic
Doug,
Just order the one cable from your OPC - they are all available individually.
Regards
Dave
Old Jul 14, 2006 | 09:21 AM
doug751's Avatar
doug751
Our OPC's are not so helpful as yours in the UK. The dealer by me mostly sells Trophy cars to rich people, and have little time for those who own older Porsche. To order a part, I must drive to the dealership and pay first, then return to dealer to receive part. They are not open on Saturdays. They will not take an order over the phone.
Thanks!
-Doug
Old Jul 14, 2006 | 06:29 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
If you have only damaged the connector they are available separately as part number #928-602-557-01, I would unscrew the connector first to check the wiring. The entire cable (including connectors) from the #1 ignition coil to the primary distributor is part #964-602-060-07 and from ignition coil #2 to the secondary distributor is part #964-602-060-08. I would not order these from your local dealer unless they are willing to price-match other dealers, they are available for ~50% of MSRP (cost + 15%) mail-order from someone like Sunset Imports in Oregon, Suncoast in Florida, etc.
Old Jul 14, 2006 | 06:45 PM
MarkD's Avatar
MarkD
Agree completely with Jason, Sunset in particular is great to deal with in my experience.
Old Jul 15, 2006 | 10:44 AM
doug751's Avatar
doug751
Thank you!
