964 Forum 1989-1994
Wheel alignment - again
Old Jul 11, 2006 | 09:15 AM
Gus's Avatar
Gus
Default Wheel alignment - again
Ok - are you just guarding your information ?/ I have had 22 lookers to my question on autcross alignment but not one reply - Is this a classified (secret)area - just looking for suggestion on/for wheel alignment/set-up for autocross - I knw that this is different from racing ( per-say) but the alignment should be relative similiar/ maybe more camber because of the slower speeds and corners.
Any one want to share or discuss set up -????????????????????????????????? Just looking for ideas to help improve handling .
Old Jul 11, 2006 | 10:45 PM
Bill Gregory's Avatar
Bill Gregory
Technical Specialist
Lifetime Member
Gus,
I'm not an autocrosser, however, in the complete absence of any other information, I'd suggest using the Carrera RS alignment specs. They may not be optimal for autocross, however, they will be better than stock street alignment specs.
Another possible source would be your local PCA region. Look on their web site or in your periodic region publication, and see who is at the top of their autocross class with a 964. Contact them and ask them directly.
There....you have at least one response
Old Jul 11, 2006 | 11:13 PM
Colin 90 C2's Avatar
Colin 90 C2
If this helps... when I used to autocross in SCCA solo2 and pro solo, I basically set the most negative camber possible and set the toe out to about 1/8-1/4" (depending on track speed)...however, this was in a Toyota MR2. I don't see why these settings wouldn't work for you.
The toe out really helps turn-in at slow speeds.
Do not drive your car on the highway with these settings, unless you own a tire store.
Old Jul 11, 2006 | 11:53 PM
Larry Herman's Avatar
Larry Herman
Basic Site Sponsor
I am certainly not the authority on these cars, yet but from my time with the 84 Carrera, and based upon how my current car is setup, I'd run somewhere around 3 degrees neg in the front and 2.5 neg in the back, with 0 toe in the front, and 1/8" total toe-in in the back with R compound tires. For street tires I'd dial it back about to 2 degrees neg in the front and 1.5 neg in the back, and see if the tires were rolling under or had even wear. It's a starting point.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old Jul 12, 2006 | 11:49 AM
Gus's Avatar
Gus
Thanks for the feed back - it is a starting point - LArry you are were I am at now - so I guess I have agood starting point to play with - I used the RS settings for the toe in on the rear - For strreet bring it back a couple of degrees is a good idea - but kind of a pain to do during the autocross season-
Again thansk for the information gentlemen - greatly appreciated
Old Jul 12, 2006 | 01:53 PM
zimpwh's Avatar
zimpwh
Excellent starting #'s. My autocross setup is nearly the same, except I run a bit of toe out up front with Micheli slicks. 225F 275R, 17" cup wheels, 1990 C4 narrow body.
