CR-1 radio's DIN layout?
I discovered that the CR-1 in my '93 964 has a multi-pin DIN to send tunes to the under-seat amp, presumably the pins are coded for LF, RF, LR, RR, and either a 'on' signal and/or power to the amp.
Questions:
(1) anyone know which pins do what? and
(2) is it a common DIN pattern? and
(3) might the connectors be readily available (like, Radio Shack)?
TIA,
Gene Rankin
Questions:
TIA,
Gene Rankin
