Impending Clutch of DMF Failure?
No I wouldnt change the starter ring, unless it showed evidence of wear that would cause your starter to begin missing at some point. But I would change the DMF.
I just dont trust rubber centered pieces to last...
Kirk
Kirk
Technical Guru
Originally Posted by RallyDogRacing
So does anyone have a used Luk DMF they would like to purge from their bin-of-parts? ... Would you have considered the starter ring a "must replace" or a "might as well"?
Sorry to hijack, but I am looking at 964s, both C2 and C4, and would like to know more about DMF.
Can anyone post what are the issues.
Also, if I understand this thread correctly, service records that show clutch replacement does not neccesarily means that the DMF was also replaced. Corect?
Did all 964s use the DMF? Is there a difference between C2 and C4?
What about 90-91 vs 92-93?
Agaian, sorry for the hijack, but information would be appreciated.
Nader
Nader
Nader
Nader
It's correct that a clutch replacement doesn't mean the DMF was replaced - but that will be because it wasn't worn and didn't need to be. I just had a clutch replaced - I was told my DMF had 30-40K miles left in it.
89 C4s didn't use a DMF. The rest did.
In summary - if I was buying a 964 I would care more about whether it had recently had a clutch / whether it would soon need a clutch (which is a relatively expensive consumable) than whether it still had the original DMF which occasionally failed (but seems to have lasted 13-16 years in the car I was viewing).
Hope this helps.
Technical Guru
Originally Posted by Nader Fotouhi
Is there a difference between C2 and C4? What about 90-91 vs 92-93?
Well thank you all for the input. I've made a decision to first do the timing-belt R&R on my supercharged 4Runner, so if I find something ugly while working on the 964, I don't have any other impending issues to deal with on the driving vehicle.
I'm going to dive in and do the clutch and anything I can get to seal & gasket wise. I'm leaving the heads & cyls on and going to try to make it past the 200k mile mark because I take a certain amount of joy in getting the most usage I can out of something before rebuilding it. It will probably be a couple weeks before I get started on this.
I'll still gladly pickup someone's used LUK DMF in the meantime.
Good point on the starter ring. I suppose it shouldn't really be on the list.
Kirk
p.s. Heads arrived today. New guides, valves, valve springs, retainers, machined for sealing ring, etc.
Kirk
