Oil Change but no oil pressure
Guys before I fire up and the sake of destorying my enigine I want to just make sure this seems normal..
I have just replaced the clutch and also replaced the oil return line.
Refilled with the same oil and now when I have been cranking for about 30 seconds total (without spark & fuel) the oil pressure is just at 1 bar and the oil level indicator is showing half full.
the tank level just seems odd as you dont get a reading until its warm unless the tank is overfilled which it cant because the same oil has been used.
Do I need to crank some more or is my pump not working or am I just being stupid!
At idle, the oil pressure is about 1 Bar, and rises with increasing RPM. So when just cranking the engine at a few hundred RPM, the pressure seems adequate.
????Why would you reuse the same oil???
Technical Guru
Thanks for the info - thats helpfull...
Yes the return pipe didnt have any caps on the end... I thought maybe something got stuck.
All seems to be ok, I havent started the car in 6 months so thats why I was a bit foggy on weather I should see pressure or not.
how does the oil breather tube syphen oil into the manifold and how long would this go on for - i.e. every time you start the engine or just the one time
I had a full rebuild - after a 6 month oil change - from full to semi synthetic oil - I am now getting big puffs on start up - not every time.
The car is driven every day and is running very well.
no smoke after the first puff - maybe a second or two
Any thoughts?
Any thoughts?
