Green wire syndrome has struck?? How to remove the radio?
I fear that the green wire syndrome (that Adrian clearly identified in his book and others have ID'd in the many threads) has struck my C4.
I discovered that my battery was totally dead, after the car sat for 2 days. (I put in a new battery ~2 months ago after purchasing the car - the battery was 7 years old). No problems with the battery until this time.
(Strangely enough, coincidently?, the night that I locked up the car, I noticed that the back-lights on the radio were still on after the car was off. Strange, I hadn't noticed that before, but maybe that is part of the magic battery drain that the 964's are famous for.)
I hooked up a charger to the battery, and a bit later after charging, I got into the car and soon the alarm started. (tracing back, I think I opened up the glovebox, and that's when it triggered ??). Anyway, I could not stop the alarm by any means, so I had to unhook the ground cable from the battery. Every time I hooked up the ground, the alarm would start again. After reading Adrian's section, and all the threads, I started looking for the "green wire". Moved some wires around behind the radio (I have the stock unit with CD controller), but couldn't see much. Bottom line, after closing everything up, including the glove box, hooking up the battery, the alarm started but it reset after a few locks/unlocks.
AND, today I noticed that the constant-volume engine speed changing, buzz in the radio is now gone. And, the radio back-lights are off.
SO, after my long story, my question - How do I remove the radio so that I can properly inspect the wiring?
Many thanks to everyone -
I've put over 1200 miles on my "new" C4. It's an amazing car, and I'm still learning. My Prelude feels like a Buick. I am going to the Intro to DE at Putnam Park in IN in June - should be fun.
DWS,
I removed my radio to trace some alarm issues a while back. In my case, it turned out that my alarm brain was fried and I needed a replacement.
Anyway, to remove the radio you will need some standard radio removal tools that look like two U shaped wires with small, hook shaped, indentions on the ends. They are available at any automotive audio shop. (In my case, a shop let me borrow thier tools and remove my own radio in thier parking lot) In order to release the radio from the bracket that holds it under the dash, you will need to insert the U shaped tools into the holes at each corner of your radio. (the holes are covered by 2 small plastic end caps that pop right off with a little pressure from a small screwdriver) Once the tools are fully seated, you will feel a snap when the hooks engage. You can then pull the radio out using the tools and some pushing from behind the dash. Be patient, it may take some effort.
Hope that helps. BTW, I diagnosed the problem with my alarm brain by borrowing a spare brain from anouther 964. All of my issues when away with the borrowed unit, so I bought a used one off ebay.
Good luck!
Good luck!
It depends on what type of radio you have... the U-shaped tool mentioned above isn't what I needed for any of the 4 964's I've had... just a little screwdriver to poke up the locking tab...
In this thread I posted a picture of the radio, at least the stock version, showing how to remove it:
https://rennlist.com/forums/964-forum/252649-radio-removal-1990-c4.html
https://rennlist.com/forums/showthread.php?t=252649
If one has to get further inside (to get at the lighter's connection, for example), there's another obstacle: it seems that the CR-1 radio slips into a metal sleeve, which sleeve seems to move a bit, but won't come out. Well, it will come out if you look v. carefully and see that there are a bazillion little metal finger-like things that impede its removal, and you have to pry each and every one away from where it grips the radio's aperture. As soon as you think you've got them all ... you discover that you don't. When you finally do, you can slide it free as well.
