wheel & offset question
hello everybody...
will these sizes fit straight on or will some spacers be needed
7.5 x16 offset 52
9 x16 offset 65
cheers steve
7.5 x16 offset 52
9 x16 offset 65
cheers steve
fronts should be ok, rears may need spacers, try here
http://www.1010tires.com/WheelOffsetCalculator.asps
cheers andrew
cheers andrew
The Cup II, 17" wheels are a 55 offset. Adding a 12mm spacer will be fine. 65-12=53...or close enough.
Hmm,
My offset on my 17s is 56.5, but I need between 10-15 mm of spacer to keep the rear wheel off the oil line but inside the fender. So why would a 65 offset require the same?
Kirk
Kirk
Ahh but with a 9 inch rim you don't have any clearance issues anyways so you can move it around the 9mm and not care. I knew it had to be something. My rears are 10Jx17 ET56.7, there is no room to play. I am going to install a slightly wider spacer this summer (15mm) to give me a little more inner clearance
Kirk
Kirk
Technical Specialist
Lifetime Member
Lifetime Member
