993 turbo twist wheels on 964 C2
anybody have 993 turbo twist wheels on their 964 narrow body?
will 18 x 10 et 65 with 265 35 18 tires fit on the rear without spacers or rubbing?
thanks!!
thanks!!
Regards
Dave
Originally Posted by Christer
And i think at the narrow body 18mm is the maximum!
But perhaps i missunderstood something!
Greetings Christian
Christian,
I think we guessed what you meant. I know the Mille Miglia 18" 10J wheels which are sold for the 964 narrow body are ET47 - hence my suggestion of an 18mm spacer. I have my suspicions that a 15mm spacer might leave the wheel a little close to the oil line. Much may depend on what size tyre is fitted to the 10J wheel too.
Regards
Dave
Regards
Dave
Interesting. I'm receiving a set of 02 Carrera hollow spokes (8x10x18) later this week. I currenlty have 15mm spacers in the rear - I'll let you know how it goes.
I see 1" (25mm?) spacers are readily available. Do you think this would push it out too far?
I tested 21mm at the rrear this weekend with 10x18 ET65 and it is the limit without bodywork!
Greetings Christian
Super Duper Moderator
I have 18x10 ET65 rears with 265's and switched from a 15mm spacer to a 21mm spacer as the tire rubbed the oil line (not at rest, only once driving).
Marc
