engine misfires when wet
Subscribe
May 9, 2006 | 04:50 AM
Hi guys,
Not long ago I washed my car with a high-pressure cleaner for the first time ever.
After the wash, the engine sounded as if it was not firing on all cylinders (spluttering and reluctant to rev). It also made noises (sort of crack, as if I had a firecracker in the exhaust) every 10-20 seconds.
After letting the engine idle for 5-10 minutes, the problem disappeared. It made me think the problem was related to water getting in somewhere, and that letting the engine heat solved the problem.
Yesterday the car spent the whole day outside in torrential rain. When I left the office, I had the same problem for a minute or two. The engine did not fire properly, throttle response was sluggish and the firecracker noises were back. After 2-3 minutes the engine stabilized and the noises disappeared.
Do any of you know where the problem might be?
It is raining again today.....
Jens
Reply 0
May 9, 2006 | 04:55 AM
I had this problem last year, and all I did was spray the HT leads, Distributor caps etc... with "Damp Start" which is a silicone based aerosol. The problem was solved there and then.
Cheers
Alex
Reply 0
May 9, 2006 | 08:18 AM
Hi Alex,
Sounds nice, and easy. I will try your fix tonight.
Cheers!
Jens
Reply 0
May 9, 2006 | 08:19 AM
Sounds like you need a car cover.
Marc
Reply 0
May 9, 2006 | 11:10 AM
Do you have the stock Oxygen Sensor?
I think Adrian has commented in the past that the generic O2 sensor is not properly waterproof, and will cause all severe misfiring if it gets really soaked.
I had one on my car, and during a heavy rain, had those exact symptoms. I subsequently purchased the actual Porsche sensor, and am happy to say that I have not had the same problem again.
Coincidence? Possibly, but it was a cheap enough, DYI fix.
Brian
Reply 0
May 9, 2006 | 11:33 AM
I doubt it's the oxygen sensor. I thought the same when I saw the title - however the description says :
"Yesterday the car spent the whole day outside in torrential rain. When I left the office, I had the same problem for a minute or two."
From cold, the oxygen sensor isn't used until it warms up - which takes a minute or two. Hence, if it was the oxygen sensor the car should have run fine for a minute or two and then had the problem, not the other way around.
Reply 0
May 9, 2006 | 11:42 AM
Hi guys,
The problem happens when I fire up the engine, and it goes away as the engine heats up. Therefore, I did not think it could be the O2 sensor.
But, it may be the wiring around the air-flow sensor housing on top of the engine. As far as I can see, it is the only part that gets wet when the car is parked in the rain.
Take care,
Jens
Reply 0
May 9, 2006 | 01:33 PM
Quote: I had this problem last year, and all I did was spray the HT leads, Distributor caps etc... with "Damp Start" which is a silicone based aerosol. The problem was solved there and then.
I read somewhere that you shouldn't allow silicon anywhere near our cars - was it in Adrian's book?
Reply 0
Explore
May 9, 2006 | 04:34 PM
I have had the same probs in the rain.
When its raining hard or surface water I get a lot of problems, car stalls will only rev witht he clutch dipped and will only pull on full throtle - not good in traffic!
I had all ht leads, plugs, caps and rotors replaced and still happens. i also sprayed the whole lot with wd40.
My conclusion is there is a earth or something under the car that is effected by the water spray.
Its imposible to diagnose as it only happens in certain rain and I'm neer carry a spear techie with me when it rains - silly me.
Reply 0
May 9, 2006 | 04:51 PM
Quote: My conclusion is there is a earth or something under the car that is effected by the water spray.
Which is exactly where your O2 sensor is.
I would agree that the symptoms that the OP described make it unlikely that it is the O2, but your description matches mine original problem to a "T".
Brian
Reply 0
Subscribe
