Strut Brace - To push or to pull?
#31
Okay, I'm not done with this. Given that the primary stress is outward, and that a rigid(metal) strut brace may transfer damage to the opposite tower in a collision, would a better proposition for a street driven car to have a carbon fiber strut brace? I share Heirsh's concern and my thinking being that in the advent of a collision the carbon fiber would shatter rather than transfer the abrupt force.
Noah
Noah
#32
Carbon fiber is pretty good in compression. Kevlar, ont he other hand, is good in tension, so how about a kevlar composite? Lots of strength in tension, but only the resin would be holding in compression and likely to break in an accident.
#36
OK, old thread, but relevant question re: installing a strut bar. Assuming I get my car on level ground for neutral installation, is it just a matter of loosening and removing the retaining nuts, install bar, and then tighten nuts? Sounds so simple it should be easy, but that's when I get paranoid. Anything I am missing? TIA. Jim
#37
Agent Orange
#38
ilko, you're the bomb, as usual. Thanks for the help. Jim
