Floor Jack point for raising front end?
I want to raise the front end to replace the brake pads today and wasn't sure exactly where is the jack point for the floor jack. I will be using jack stands as well and know where they will go. Any pics?
Thanks...
Thanks...
You raise the car from the rear jack point.If you look under the car just in front of the rear wheel there are two hard points for the jack.As you raise from the rear the front end will come up to where you can place the stand up front.
