New Headlight Lens
My drivers side headlight has a stone chip ,can i buy just the lens or is it all one assembly,design 991 uk shows just the lens but a local dealer says its all one piece,any advice thanks
Originally Posted by ltc
H5 or H4 headlights installed?
Marc
Marc ,they have the nubs,so what should i do? and where ,also Layland motors is tuning my baby up,they said the previous owner took good care of her,just purchased last aug.However they said the clutch is going out ,no noises or clunks just pedal out to engage,what should i expect and what do you recommend, dual mass or lightweight?How much Thankyou
You have standard US H5 headlights.
A simple upgrade to H4's (Euro) headlights would be simple and a big improvement at night. H4's have a seperate lens assembly, so you can replace just the lens if it should get a stone chip/crack.
FWIW, I installed H4's in my 94 RSAmerica and was very pleased with the results.
It's been discussed MANY times (fairly simple DIY) and you can buy complete kits from several sources:
http://www.vertexauto.com/index.php?...detail&sk=3934
http://www.vertexauto.com/index.php?...detail&sk=1789
(these can be painted to match your body color, if you don't like the look of chrome rings. I had Eric at www.bumperplugs.com paint my primered H4 rings Midnight Blue metallic....as always, a perfect match)
http://www.schatzmotorsport.com/Merc...egory_Code=850
Well a new bosch H5 lens is about $140.
A new H4 system will go for about $450 for both sides including labor. Many who upgrade to H4 also upgrade the harness and put in a relay so they can use 80/100 bulbs which are not road legal.
The H4 beam is better than the H5 in terms of pattern and spread. A cheaper alternative is to replace the lens and also the bulbs. I liked the Philips Vision+50 for hte H5.In 50/65 spec, the H4 bulb has 1500lumens vs 1200 for the H5 at hi beam 45/65 at DOT standards.
