Noisy rear blower - can it be lubed?
Technical Guru
Originally Posted by Euromagination
There are still things I want to figure out though because I know the front blower motors can push plenty of air without the rear one, the problem is just that when you disconnect the rear one the front ones dont work at all. VERY weird, but there has to be a way around it. Look for my recent threads about it if you are truly interested.
Originally Posted by JasonAndreas
Did you have any luck with Bill Gregory's article, "Bypassing Your Heater Motor?" I seem to remember my front blowers working normally with the rear blower disconnected but I have a "newer" climate control unit.
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Which parts numbers will work? Does it have to be a 964 climate control or will similar-looking climate controls out of other models like the 928/968 work? (I'm asking just to widen my range of possible fits.)
I really don't understand what the "newer" ones have that the older ones do not? Definitely an issue if putting a bypass on a '90 car.
-Harry
