Why is nothing easy on these cars?
Originally Posted by jimq
Seem when I checked into a rebuild kit including the metal brackets it was almost $200 per caliper for the kit. Maybe i was looking at the wrong brake kit.
Those screws get really rusty and i could not remove mine.
Originally Posted by Pesty
...Perhaps I have been spoiled with japanese cars and now Im paying for all those years of trouble free motoring....
Your description of corrosion, oil leaks and engine mechanical failure makes me think perhaps you have a neglected and possibly abused example. Mine has given no significant operating problems in the three years I have driven it.
Repair and maintenance is challenging in some cases. Compared to the exotics of similar performance, a 964 is reliable and a joy to fix when that is needed.
Phil,
Spooky coincidence - I was in Unit Eleven today, I've got a pair of 993(?) turbo calipers (huge and silver) that have been given to me - same problem, corrosion between the spring plates and the caliper. All eight of the screws attaching the plates to the caliper have snapped off, it's nearly impossible (and not advisable anyway) to split the calipers to drill out the screws so here's Mr.Johnny Hollands cure:-
Take 8 nuts with internal diameter close to the external diameter of the spring plate retaining screws (M8 I think). Using a pillar drill with a 7/16 drill bit, drill the centre out of the nut until there's just a thin 'wall' left at the bottom of the nut. With the caliper in a vice, drop the nut over the protruding piece of the screw. Crank up your MIG welder, and weld the nut onto the thread. Wait until the nut stops glowing red, attach socket and undo - works a treat. I think the heat generated by the welding vaporises the thread lock on the screws, which is what makes them such a bu**er to remove. Clean up caliper (I'm taking mine for a quote for powder coating in the morning), re-fit spring plates using stainless dome head Allen bolts with some copper grease between the plates and the caliper. I've orderd some adaptors and will be fitting these to my C4 when I get it back from the bodyshop - a sort of poor mans version of big reds!
Barry
PS I forgot to take my camera with me, it would have made a cracking 'how to'!
Barry
Mine were knackered too, even the lovely ones from Christer had corrosion behind the plates, I just stripped them, clean huge chunks of oxidation from them, hammerited them (is that a word?), painted them yellow, polished the plates up again and bought some stainless steel buttonheads to replace the rusty screws..
Took about 3 days all in....
Kevin.
Kevin.
I've had 4 964's and they are very well built - on par with the 65 911 that I had for so many years. It's interesting how some 964's are much better/worse than others. I think garage storage is a crucial element to a 964 staying in good condition overall - any old car, for that matter!
Howard - the worst part of the ML320 is the wheels weigh about 100lbs each!!! Uggh!
Originally Posted by Sten
...got a pair of 993(?) turbo calipers (huge and silver) ...a sort of poor mans version of big reds
Anyone have a source for the plates/screws/seals or a complete rebuild kit?
Phil,
The replacement calipers were £400 each apparently. I think you have to offset labour costs against the new part price - plus there was no guarantee the screws would come out cleanly. I should have a spare pair of standard front calipers available shortly.....
Barry
Barry
Springer how do you neglect or abuse a speedo face?
UV exposure, heat and humidity degrade most anything with time. Corrosion? Where do you drive? Mine has none from driving in Atlanta - not pristine, but better than industrial or sea coast locations. Garrett has already made the comment that dry garage storage is the only way any car can survive 15 years and still be in good shape.
I did not intend to offend, but I don't understand the Porsche bashing. I thought this was an enthusiasts' forum. Face it, there are pristine 964s, and ratty ones. The difference is due to neglect, abuse and exposure to the elements. Nothing lasts forever, but a 964 is an exceptional car and holds up much better than most.
