Where on the car do you connect tie-downs for trailering?
I had my car professionally transported over 2,000 miles and they used "over the tire" tie downs. They told me that's all they use, as it eliminates stress on the car and tiedowns and it allows the car to "ride" with the bumps in the road.
I personally think this is the way to go.
If any of you would like additional info. on the "over-the-tire" tie downs that we , Intercity Lines, use shoot me a p.m..You can retrofit them to your own trailers and eliminate the hassles and potential problems of tying the car down with chassis straps.
Dave Wilson/Intercity Lines.
Thank You,
Jim
Intercity Lines
1-800-221-3936 x205
jim@intercitylines.com
www.intercitylines.com
'69 MBZ 6.3
'16 Cayenne
'32 Ford highboy, Cadillac powered
Thank You,
Jim
Intercity Lines
1-800-221-3936 x205
'69 MBZ 6.3
'16 Cayenne
Dave: Do you tie the straps down to D-rings or E-track?
I'm happy with the Autometrics hooks for the rear, but my car is so low the front is an issue and I really dislike the "through the wheels" straps. I've considered the over the tire straps for the front, but it would be difficult to get access to D-rings (again due to car clearance). I seems E-track would be a bit simpler.
We use the series "E" track with our straps. Both the track and "over-the-tire" tie-down straps can be purchased from Vulcan Chain Corp. in Detroit. Their number is 313-935-3013. Don't think they have a website.
Ask them for the Intercity spec. tie-downs and galvanized "E" track. The galvanized track looks better and last longer than the green painted track they also sell.
Hope this helps.
Dave Wilson
Hope this helps.
Dave Wilson
Hope this helps.
Dave Wilson
Hope this helps.
Dave Wilson
The series "E" track is what holds the tie-down-straps to the trailer floor. The strap runs from the track, up and over the wheel and then back down to the track.
For a photo go to the "Transport Equipment" page on our website. intercitylines.com. You'll see a red Corvette sitting on "E" track with an over-the-tire strap holdiong the car in place.
