do 94 models have the same warning light icons in oil temp/press gauge?
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
I am trying to figure out if the speedometer face replacement shop installed the incorrect gauge face on my oil temp/pressure gauge (it came this way on my car so I don't know the original). The warning lights appear totally different from the 1992 version that I am familiar with. I have a feeling the shop installed a 993 gauge face instead, but don't know what a 993 face is like either!
Does anyone know if the 964 series had identical warning lights? For example, on this gauge face, the Check Engine light is not at the bottom left of the gauge, but is at the top in the middle. Also, there are strange ABD icons at the top - a green one and a red one where my usual green PDAS activation light would be.
I am confused, and before I call up the speedo shop and tell them it's wrong, I want to be sure!
Called and checked - they did indeed install a 993 gauge face! Oops. Kudos to them, as they'll replace it for no charge with the correct 964 version. I must say, I like the 964 icons better!
