964 Forum 1989-1994
Wheel offset vs. width
Old Feb 14, 2006 | 12:14 AM
Rick964's Avatar
Rick964
Default Wheel offset vs. width
When you move to wider wheels would the offset change or stay the same? I am looing at moving from 9x17 ET55 wheels to 10x18. Should I be looking for 18 with an offset of about 55 or do I split half the width of the wheel and add that to the offset so I would want about a ET67 more or less?
Old Feb 14, 2006 | 12:24 AM
Bill Gregory's Avatar
Bill Gregory
Technical Specialist
Lifetime Member
Other way....when you go to a 10" rim, you want to be roughly at 47mm offset. If you go with 67, you'll need a spacer.
Old Feb 14, 2006 | 03:09 AM
Rick964's Avatar
Rick964
Thanks.
