8.32 rack and pinion into g50 03
I will be installing the 8.32 r and p but wondering how much improvement should I expect. At the same time I will be putting a lsd and lwf together since the gearbox is going to be down.
Thanks for any comment.
Winsome
Winsome
The torque multiplication will be 16.2% (4/3.44=1.162) greater in each gear, but each gear will be 14% (3.44/4= .86) shorter i.e. you top speed in each gear will be 86% of the original top speed.
I'm sure you will feel this in the seat of the pants, particularly with the LWF.
