Oil Level Gauge Readings
Actually it's only "pegged" when I stop and at an idle, otherwise it's somewhere around the 3/4 mark.
While on the subject, where on the dipstick should the oil level be? If the guage typcially reads the same level as the oil on the dipstick, does that mean the ideal level should be about half way up the indication range on the stick at idle, when hot?
Indy,
You didn't really think I would let you drive did you? ;-) By the way, it's a Tiptronic, does that mean its still a real Porsche?
Indy,
You need to get rid of some oil asap . Trust me ! You got to much oil !
" You didn't really think I would let you drive did you? "
Sure , as a fellow 964 owner why not , I would let you drive mine .
"By the way, it's a Tiptronic, does that mean its still a real Porsche?"
If its good for F1 , its good . Did you see the post about the shift on the wheel
job someone did . Tips are cool .
1 Post
As others have already said, you need to drain a bit of oil. You can use a turkey baster to suck out a few ounces at a time. I've found, as someone has said previously, that the difference between "halfway" on the gauge and the needle being in the red can b e only a few ounces (gauges might vary). I've found that using the turkey baster is easier and less messy than opening the drain plug.
DITTO....with CHIP.......if I fill to max line......gauge goes to top.....etc.etc......keep oil between max & min on the stick and you will be o.k. Slappy is right on !!.... All comment's have you covered PETER.....Welcome Aboard !!!!
Hmmm......vestigial organ.....Hmmmmm.....I like it
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
OK OK I get it! :-) I better take out some oil.
Thanks for sharing your experience everyone. Please don't get bored with my simple questions, ok?
Thanks again.
Peter
Thanks again.
Peter
Originally Posted by Slappy
There is no substitute for the dipstick ... oil gauges, as far as I am concerned, are a vestigial organ on a car.
1) No need to open the engine lid
2) It does not need a wipe rag
3) It won't get dirt or foreign objects into the oil
4) It won't burn you
5) It won't get oil on your hands
6) It won't drip oil in the engine compartment or on your paint
7) It won't scratch the paint if you are careless
8) It won't forget to check the oil
9) You won't forget to put it back if the phone rings while you are trying to use it
10) A gage will tell you if you start to lose oil while you are driving
Vestigial? The height of refinement I say.
Love a challenge? I'll bet the more creative types out there can come up with 10 more advantages for the gage (or the dip stick, for that matter).
Burgled
Originally Posted by springer3
Obviously the dip stick is needed to check the gage every so often. Advantages of the gage over the dip stick:
Love your list Springer !!!
BUT ...
the oil gauge CAN lie/fail ... the dipstick NEVER lies/fails.
I check my oil ONCE a week ... religiously (when its not stored away for the winter months).
BUT ...
