964 Forum 1989-1994
suspension upgrade qoute
Old Feb 4, 2006 | 03:29 PM
last toy's Avatar
last toy
Default suspension upgrade qoute
Just got a quote to install Bilstein shocks and Eiback Pro-Kit springs and corner balancing for about $2300 US. Does that sound reasonable? Based on prices from Pelican, this quote seems reasonable. Was thinking about doing the install myself but not sure if I have enough proper tools or jacks to do a good job. The Pro-Kit will lower the car about 1.75 inches.
Old Feb 4, 2006 | 04:19 PM
hawk911's Avatar
hawk911
Seems high to me, but then I used H&R turbo springs with the Bilstein shocks and did the install with help from RallyDog. Cost me $850.00 for parts, but I got the springs for half the cost. Corner balance and alignment should be 300 or so. Is it worth the time to install yourself? At $1000 I would say so.
Old Feb 4, 2006 | 05:13 PM
LouZ's Avatar
LouZ
From: Philly Area ----- George Washington took a dump in my backyard!
I agree with Hawk911, I spent about $1100 - 1200 for the parts (Bilstein / H&R) and $350 for the 4-wheel alignment and corner balance. So is it worth $700 +/- for someone to do it for you?
The job was relatively straightforward, and took the good part of a lazy day.
Parts = $1100, Labor = $350, Time = 6 hours, Experience = PRICELESS
Old Feb 4, 2006 | 11:30 PM
Marc Shaw's Avatar
Marc Shaw
Super Duper Moderator
Don - pay me $1000 and I'll fly to Ontario to do it for you.
I paid US$1600 for my H&R coil-overs which I am installing myself and plan on another US$350-400 for the alignment, and corner balance. US$2300 for shocks and springs (even with alignement/corner balance) seems high.
Marc
Old Feb 5, 2006 | 01:09 AM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
Don,
Rennlist sponsor AJ-USA is having a 10% off special until February 8th. At checkout you enter promotional code SUPERBOWL and the Bilstein HD's for the MY90 964 are only $607.23USD.
Old Feb 5, 2006 | 10:11 AM
last toy's Avatar
last toy
thanks guys. You gave me something to think about. just needed some good advise.
Old Feb 5, 2006 | 10:19 AM
Jeremy Pinsly's Avatar
Jeremy Pinsly
Don, was your price just for the labor or for parts AND installation?
A corner balance and alignment should cost in the $400-$500 US range. I was quoted about 10 hours by my dealer for the installation and of the shocks and didn't do it. Probably saved about $1000 dollars.
Old Feb 5, 2006 | 10:57 AM
last toy's Avatar
last toy
Jeremy, maybe I wasn't that clear. The quote was for $2300 for the parts, installation and balancing. But from the feedback, that still sounds high. If the job takes 10 hours as you were quoted and my shop charges $85/hour, then that's where the $1000 savings comes in less the balancing cost. I guess I am confused on the parts cost. Pelican advertise their suspension kits from $2000 to $2800.
Old Feb 5, 2006 | 12:59 PM
Gary R.'s Avatar
Gary R.
I just bought the Eibach spring set and new Bilstein HD's for my car, $933 inc. shipping to CT with the discount. Great deal!
Old Feb 5, 2006 | 06:31 PM
JasonAndreas
Technical Guru
Gary,
Did you previously own a blue C2? If so, could you post your ride height and alignment settings (and whatever else you did to it)? I saw a photo of it and the way the wheels filled the wells looked perfect.
Old Feb 5, 2006 | 11:58 PM
Gary R.'s Avatar
Gary R.
It's actually Amazon green Jason and I still own it. It has H&R's on it now but whoever put them on left the original shocks in and as I am not sure just how long ago it was done I figured I would just change out the H&R's while i'm in there.
Here is my 93 as it sits now, I believe the Eibach's won't change the height. As for the alignment I leave that in the hands of Hairy Dog Garage, they set my 91 C2 up with a touch of negative camber and i'll aske them to do the same with my 93. Be glad to measure fender height when all is done, most likely in about two weeks (have to finish painting my track car 1st!).
Old Feb 6, 2006 | 02:43 AM
JasonAndreas
Technical Guru
That's the one! The 18" wheels with a touch of negative camber really transforms the look of a 964.
Old Feb 6, 2006 | 08:30 AM
Gary R.'s Avatar
Gary R.
Can't go wrong with www.wheelenhancement.com and Fikse wheels! Will leave a very large whole in the wallet though..
Old Feb 6, 2006 | 09:34 PM
Chris M.'s Avatar
Chris M.
What about the "don't put 18s on a 964" warning from PAG?
c
Old Feb 6, 2006 | 09:53 PM
last toy's Avatar
last toy
Chris, what was the PAG warning about. I have 18in wheels and see no issues with rubbing or handling. I didn't notice any warnings in Adrian's book.
