FIRE in the hold !
#47
Hi Mark,
Glad the car will be resurrected - and so quick too by the sound of it. Good pics!
If there's anything I can do let me know - stupid really but HK still feels like next door !
Good luck
Cheers
Good luck
Cheers
#48
Super Duper Moderator
Originally Posted by Tinwan
Hi all,
For anyone interested, the fire damage restoration continues , engine & gearbox back together with new clutch & flywheel in next week.
Cheers, Mark
Cheers, Mark
Are you skipping the sound insulation pad or is just not in yet?
Marc
#49
Fire in the Hold - WIP 3
Hi all,
C4 should be on the road by this weekend, motor/gearbox back in tomorrow and connect all the wiring, then paint shop to finish the around the top of the engine cover and some detailing here and there.
Cheers, Mark
Cheers, Mark
#50
The car is coming along nicely!
Was this part only on the 1992 and earlier cars? If I remember right, I remember checking if all recalls were done on my 1993 964 when I bought it, but now I don't remember....maybe I should call the dealer and have them run the VIN?
Originally Posted by JasonAndreas
From the recall:
......800-424-9393.
1989 PORSCHE 911
1989 PORSCHE CARRERA
1990 PORSCHE 911
1990 PORSCHE CARRERA
1991 PORSCHE 911
1991 PORSCHE CARRERA
1992 PORSCHE 911
1992 PORSCHE CARRERA
......800-424-9393.
1989 PORSCHE 911
1990 PORSCHE 911
1991 PORSCHE 911
1992 PORSCHE 911
#51
Fire in the Hold - WIP 4
Hi all,
Nearly there, roof repaired and all engine components connected including the electricals and exhaust etc. Will be on the road we hope by next weekend.
Cheers, Mark
Cheers, Mark
#52
Fire in the Hold - WIP 6
Hi all,
Cheers, Mark
Cheers, Mark
#55
Finally, where is this part located ?
Picture, please...
Picture, please...
#56
Picture, please...
Picture, please...
Originally Posted by Computamedic
I can't show you - but if you put your left hand between the engine compartment electric panel and the pipe coming out of the rear blower you should be able to feel for two wires apparently attached to the blower pipe. Those two wires are spade connectors which attach to the resistor in question. The resistor itself is snapped into the blower pipe and can be removed with a little effort and conviction.
Hope that helps. If you NEED a photo I can take one later.
Regards
Dave
Regards
Dave
This thread is very disturbing so I want to check the resistor and balast before it's too late
#58
Steve,
The ballast resistor in discussion is part 10 in the attached diagram. It's difficult to get a photo since there is virtually no clearance around that item to get to see it.
The resistor clips into the hard plastic plenum for the rear blower and the suggestion is to hold it in with a tie wrap around the plenum just to stop it falling out. If it's clipped in correctly there's not much chance of it falling out - but better safe than sorry!!!
Regards
Dave
Regards
Dave
#60
That's the part alright - but you can't really tell if it's been replaced without removing it and checking if it has the bi-metal safety cutout. Yours looks like it's been there for a while so it could be an original. You would probably only be able to tell if it's the updated part by looking at the part number on it - it should be 964.616.550.02 if it's the later part.
Dave
Dave
