964 Forum 1989-1994
Primary silencer bypass (uk)
Old Jan 20, 2006 | 03:49 AM
964rh's Avatar
964rh
Default Primary silencer bypass (uk)
Hi
Has anyone got a cup pipe surplus to requirements that they want to get rid of. (Cheap!!)
I have a g pipe on my C4 at the min. and is to loud for most UK tracks.
Rob
Old Jan 20, 2006 | 02:03 PM
Sten's Avatar
Sten
Rob,
Noise test on my car with STANDARD exhaust was 103dB at Goodwood - I run with a G-pipe but have standard silencer for track days!
Barry
Old Jan 20, 2006 | 02:29 PM
pete000's Avatar
pete000
I just got a G pipe. I was hoping it would not be too loud, no I am nervous. Is the primary bypass quiter than the secondary??
Old Jan 20, 2006 | 04:34 PM
Rick964's Avatar
Rick964
What noise limit to UK tracks impose? Over here most tracks impose 92-93 dB, my C4 ran with a secondary bypass and never had a problem.
Old Jan 20, 2006 | 05:12 PM
jimq's Avatar
jimq
Burgled
I have a cab. It was loud the first few times I drove it but got use to it quick. I dont really notice a major noise difference while cruising then before the change.
Old Jan 21, 2006 | 11:05 AM
Red rooster's Avatar
Red rooster
Robh,
You are right to be nervous. Some places -Goodwood,Castle Combe it is debateable whether a 964 with the full system will pass noise !!!!!!!!!!!!!!!!
You stand more chance with a Cup than a G .
All the best
Geoff
Old Jan 22, 2006 | 07:14 AM
964rh's Avatar
964rh
Rick
A lot a tracks in the Uk are now running quiet days which can be as low as 95db max. With the cat bypass and g pipe my C4 was running 107db at an airfield recently, which would ban me from most proper circuits. (and nearly did from the airfield!)
A friend of mine is running a cup/cat bypass setup and runs at about 102db on a RS which seems to be ok if you sneakily cut back 500rpm or so on the static test and backoff slightly on the drive by one.
Regards
Rob
