964 C2 rotors
964 C2 rotors
Can't find this in my books - just wanted to verify. Adrian's book says the thickness should be 24mm rear and 28mm front. Someone else posted that 1.4mm is all you can lose before they're toast. I measured my rears at 23.5mm with some minor grooving and still have pretty thick pad left.
I'm thinking a turning on a good machine and new pads would get me more life out of them - but after reading some of the posts I'm thinking I should leave well enough alone. They work fine now. Leave them? What if they squeal? (either my fronts or rears do, don't remember now because car hasn't run for couple of months and won't run for another couple of months).
-Chance
-Chance
Technical Guru
