Bucket Seats - RS / Speedster
This thread on the PCGB forum covers the install of PPs into a 3.2. Not quite the same, but you'll see what I mean about the RS seatbelt bracket.
http://www.porscheclubgbforum.com/tm...osition澐
Jamie
Jamie
Ah, got ya Jamie, I've got the mount from southbound trimmers which gets this problem sorted without the cost of 115 quid from OPC according to them!!
See how there is an extra hole diagonally opposite the 3 holes for the rear of the seat.
Aaaaaahhhhhh ! Now that's very cool indeed - would have saved me a whole lot of hassle ! Funnily enough I ordered my side mounts from Southbound too, however as I have SPGs, not PPs, the side mounts are sligtly different to fit the narrower seat, and I guess Southbound haven't made their own versions with the seat belt hole pre-drilled as for the PP - shame ! Mine are the genuine Recaro items. I also like the way that yours have two bolt holes in the bottom for mounting - my Recaro mounts and Sparco sliders only have one hole so you can only use one bolt to hold the backs of the seats down. I've always assumed there was a good reason Porsche used two bolts so it made me a little nervous only to use one. I suppose I could simply drill another at some point though ! By the way the RS brackets are only £25 each, so whoever told you £115 was talking ***** ! I'm sure Southbound charge a pretty penny for their mounts which might negate some of the saving, but then again it's a very neat solution !
Jamie
Jamie
