Monday- what have you learned?
Originally Posted by hawk911
learned I need a gasket between my HT sensor and the plastic blowertube. I may also need a new O2 sensor.
Do you think that the gasket is contributing to your idle/start issue? Mine is a little loose too.
no; just wondering. I plugged the hole with my finger over it, and no difference, so I'm sure it's not a gasket issue. Kris thought it might be my sensor, as that seemed to resolve his idle issue, but not the case for me. Still just looking for ideas- cheap ideas.
Originally Posted by Kahdmus
marc,
Got a piccie of the xm radio mounted in the p-car? Thx, --H
Marc
At approx. 45 ... 75'C in basic stage (9 V)
< 40'C basic stage off
> 75'C to max speed stage
< 70'C max. speed stage off
If the ignition was turned on for at least 30 seconds, temperature sensor (T) activates pertinent after running of the heater blower which could be max 15 minutes long on a stopped car (ignition off). Electronics of heater/air conditioner controls monitor temperature signals up to 15 minutes after the switching-off of blower after-running or after turning off the ignition. Heater blower after-running with temperature > 95'C and ignition turned off.
After-running switched off at approx. 93'C"
and I learned I might actually get my transmission back before the end of the year.
