replace brake pads DIY?
Subscribe
Dec 13, 2005 | 10:51 PM
Sorry for such a dumb question, but is there a good DIY for replacing brake pads on the 964? I am going to throw in some pagid oranges and want to see a good HOWTO.
I searched, including the DIY section with no luck. Perhaps it's so simple it does not require one?
TIA
Reply 0
Dec 13, 2005 | 11:42 PM
There's this one for 993s, it oughta help...
Reply 0
Dec 14, 2005 | 12:25 AM
Quote: There's this one for 993s, it oughta help...
This is the one I was going to link to but you beat me to it!
heres another:
http://www.pelicanparts.com/techarti...brakepads2.htm
This is the easiest DIY you will ever do. First time maybe 2 hrs, second time 30 minutes!
One thing you might also be interested in is modifying the pad sensors to keep the light from coming on.
I got fed up with buying new sensors the times I changed my brakes. I also got p'd off when the light came on and I had to go around each corner to work out which was the faulty sensor so I made dummy sensors out of the old ones: cut of the plug, cut the 2 wires so they are about 2 inches long, strip, solder and cover with some heat-shrink tubing, then just plug them in. Just remember that you will get no warning lights when the pads get thin in future.
https://rennlist.com/forums/showthre...ghlight=sensor
Good luck!
Reply 0
Dec 14, 2005 | 12:56 AM
egg-cellent! thanks guys!
Reply 0
Dec 14, 2005 | 07:59 AM
Keep in mind unless your rear calipers have been updated to 92+ style you have smaller pads on the rear. Be sure to check if they are 2 or 4 piston calipers.
Reply 0
Dec 14, 2005 | 10:16 AM
Quote: Keep in mind unless your rear calipers have been updated to 92+ style you have smaller pads on the rear. Be sure to check if they are 2 or 4 piston calipers.
Jim's right... if you had a C2. The C4's pads are the same front and rear, regardless of the model year
Reply 0
Dec 14, 2005 | 11:02 AM
Quote: Jim's right... if you had a C2. The C4's pads are the same front and rear, regardless of the model year
oops! didnt see the C4. Forget my ramblings
Reply 0
Subscribe
