side marker lights
I'd like to add side marker, turn signal lights. The wiring diagram looks like the T24 and T25 connectors should be in the spaces in the far recesses of the luggage compartment up by the dash. However the coding on the wires on the connectors I see are not correct. Anyone know what these do?
First is right side. Second is left side.
I can reach the left side and it has power when the key is on.
And the answer is yes, there are connectors present to connect to harness 177 so you can have side marker lights without stringing wires and splicing into other wires at front turn signals.
