964 Forum 1989-1994
Flushing brake fluid
Old 12-06-2005 | 03:11 PM
Jeremy Pinsly's Avatar
Jeremy Pinsly
Default Flushing brake fluid
How many cans of ATE Super Blue are required to flush the brakes on a 90 C2? Should I order 2 or 3 cans?
Old 12-06-2005 | 04:03 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
Post
Two should do the brake lines and clutch slave cylinder, with a bit left over for subsequent bleeds.
One note on ATE Blue. The blue dye will tend to leave a 'ring around the bowl' in the brake fluid resevoir, making it hard to tell the actual level inside without unscrewing the cap and taking a look, due to the staining of the plastic.
ATE Type 200 (a.k.a. ATE Gold) is the same fluid, without the blue dye, thus avoiding this problem and priced the same as ATE Blue.
Some people alternate between Blue and Gold, as it makes it easy to tell when you've flushed the system completely (just wait for the color to change).
Are you using a Motive to assist in the fluid flush?
Best of luck,
Old 12-06-2005 | 07:31 PM
Bill Gregory's Avatar
Bill Gregory
Technical Specialist
Lifetime Member
FWIW, I use ATE Gold, as, as Lewis points out, the blue will stain the white plastic.
Old 12-06-2005 | 11:45 PM
Tom W's Avatar
Tom W
I find one can more than adequate for a flush. I'm one who alternates between blue and gold as it makes it very easy to see when the old has been replaced.
Old 12-07-2005 | 12:25 AM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Like Tom mentioned, one can will be enough. But I always order them in two's or three's
Be sure to bleed the clutch while your at it. You'll be amazed at what that fluid will look like...
Old 12-07-2005 | 09:04 AM
Jeremy Pinsly
Lewis,
JimQ and I will be doing a lot of work after christmas. He has ordered a power bleeder (not sure which one)....We are swapping the brake lines and the suspensions on our cars....
Keep your fingers crossed.....
Old 12-07-2005 | 09:58 AM
jimq's Avatar
jimq
Burgled
I ordered a Motive off evilbay. Figure I can use it on the Benz also as its a PITA to bleed by pumping the pedal.
Now if i can only find one of those 1/2" 10mm torque sockets local. My mission for this weekend.
Anybody want to stop by on Dec 27 we could always use the guidance. Seeing as we are both engineers I am sure we can make this very difficult
Looking forward to the adventure. My Girlfriend promised to come by to make sure we arent stuck under the car and lift!
Old 12-07-2005 | 10:57 AM
Marc Shaw's Avatar
Marc Shaw
Super Duper Moderator
Originally Posted by jimq
Now if i can only find one of those 1/2" 10mm torque sockets local. My mission for this weekend!
I ordered one from the Snap-On web site in preparation for my suspension swap and had it in 2 days - Wow! That is fast service.
Marc
Old 12-07-2005 | 11:33 AM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
Post
from our own Mr Bill Gregory:
http://tech.rennlist.com/911/pdf/brake_bleeding.pdf
And in case you hadn't stumbled across this useful list:
And here's another:
http://www.pelicanparts.com/techarti...eed_brakes.htm
Old 12-07-2005 | 12:06 PM
Marc Shaw's Avatar
Marc Shaw
Lewis, you for got this one.
Marc
Old 12-07-2005 | 12:18 PM
Jeremy Pinsly
What ID tubing is required for the nipples on the bleeder valves?
Old 12-07-2005 | 12:23 PM
jimq's Avatar
jimq
Burgled
I have a waste fluid bottle from a useless vaccum bleeder with the hose on it. Its just aquarium air hose size.
Jeremy Pinsly
In Garrett's write-up, he talks about this:
"Following the brake bleed, I followed Adrian's good instructions for bleeding the accumulator (black ball), then the solenoid block. This was quite easy to do. I was amazed that out of the accumulator came BLACK brake fluid! Whoa!!! I wonder how old the fluid was!! Wish I had the old records!! "
Are the accumulator and solenoid block specific to the C4?
Old 12-07-2005 | 12:41 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
Marc
Sorry, my bad
Old 12-07-2005 | 01:25 PM
jimq's Avatar
jimq
Burgled
I am changing out the Bias valve also to a 55 bar valve. Is there an additional step to take in bleeding this or will it self bleed with the rest of the system?
Quick Reply: Flushing brake fluid
