Sorry if I'm kicking a dead horse... air filter Q
#31
Has anyone ever tested the different air filter setups? Stock vs K&N vs K&N drilled vs K&N cone Vs Fabspeed?
I have just a stock setup and was looking at cutting my factory box to be like the Fabspeed setup. However, the only time you would get a decent performance gain from this type of mod is if you are drawing colder air. By drilling or cutting I would think you would get more air but it would be warmer than the stock setup. Anyone try ducting from near the rear spoiler? (Kinda like a turbo setup)
#32
CH,
For interest put the rear spoiler up and take a look at the intake pipe position .Couldnt be a lot better !
The 993 turbo ran an extension to ensure that intake air and the stuff off the intercooler didnt mix !!! Cutting the airbox top off makes more intake noise - nothing else !!!!!!!!!
Your choice .
All the best
Geoff
Your choice .
All the best
Geoff
#34
Geoff,
My concern with the intake opening is that it is pointed towards the engine, which will be drawing hot air at stop or low speeds. Going fast the air won't have a chance to heat up, and this isn't my concern. I can't remember the exact releationship but don't you gain around 10% HP for cooling the air 10 C(turbos anyway, hence intercoolers)
I did an AEM V2 CAI upgrade to my V6 Accord and not only sounds great but there is actually a power difference. Dynos showed almost 10 hp @ 5k rpm and 10 ft lb of torque. This was accomplished by routing the intake into the fender, away from engine heat and relocating the air inlet sensor.
I guess if it was possible on the 964 someone would have done this by now, but I still wouldn't mind trying to satisfy my own curiousity.
If only it was summer
#35
Technical Guru
#37
Originally Posted by Slappy
When the time comes to sell my 964, if the buyer is hemming and hawing on the sale because I don't have a stock air box ... oh well !!!
