RS Steering wheel
RS Steering wheel
Got the 993 RS Steering wheel from another Rennlister Mark in Taiwan last week and installed today. Looks fantastic! It makes the interior looks much more modern and it has better grip than the previous thin, 4-spoke one (non-airbag). Also changed new brake pads, rotors, door arresters, drive shaft seals, and clutch flexible hose at the same time. My X'mas project done at Thanksgiving...
Here are some pictures I took today...
Sea Eagle
Just did mine this wekend as well. Same wheel . For once it was cheaper for me to buy it from the Australian dealer, and import it , than go by the internet. It arrived in 10 days and took 15 minutes to install.
Just like the thread on this forum said. Follow this instruction and you can't go wrong.
http://www.964kevin.dsl.pipex.com/Ca...ring_wheel.htm
For anyone without airbags and the old steering wheel, its makes a lot of (cosmetic) diference. And is frightenly easy to do.
Sea Eagle
Sea Eagle
I have this steering wheel as well....and it is about 10mm smaller than the original one on mine...it was the main reason I fitted it....couldn't turn a sharp corner and clutch/brake at the same time due to some thigh obstruction
Stuart, I like the wheel too, but as you say many pounds on ebay. I also have a blue interior with matching four spoke. I'm sure I could live with a black one if one appears at a reasonable cost.:-)
