964 RS Flywheel parts needed
hello,
I would like to install a Lightweight Carrera RS flywheel in a 90 964 C2. Does anyone have the following part numbers ?
RS Clutch disc
RS Flywheel
RS pressure plate
Bearing
Pressure plate tube
Pressure plate bolts
Ring gear
Ring gear bolts
Guide tube
I searched but couldn't find a thread with these. Any help would be greatly appreciated
RS Clutch disc
RS Flywheel
RS pressure plate
Bearing
Pressure plate tube
Ring gear
Ring gear bolts
Guide tube
Don't have the part no.s, but you ocan buy this as a kit - clutch & flywheel with all corresponding parts you need to do the swap. Have a look at www.design911.co.uk for forther info - where I got mine from.
Andy
Andy
Welcome art911!
If you include more information in your signature it would be easier to help you. In this case it would particularly useful to know where you are based so that people in California do not recommend shops in their area when you are actually based in New Zealand for example.
As Andy has said, most of us that have done this modification have purchased it as a kit.
Without re-opening the discussion around the 'side-effects' around installin an RS flywheel - you should search the forums for more information regarding possible stalling issues etc....
Let us know how you get on!
I searched for "lightweight flywheel" and got 103 hits...
Anyway if you're going for the lighweight flywheel I would also recommend a kit like the one on offer by http://www.design911.co.uk for 1153 €
964-102-239-31 (1) LWF Flywheel
964-114-143-31 (1) Ring Gear
931-102-111-00 (1) Pilot Bearing
928-102-151-01 (9) Flywheel Bolt
950-116-813-30 (1) Guide Tube
964-116-011-61 (1) Clutch Disc
N-014-715-3 (9) Cheese Head Screw M8 x 45
944-116-080-01 (1) Release Bearing
999-113-426-41 (1) Rear Main Seal (RMS)
the different pressure plates available are:
964-116-027-90 968 (green)
964-116-028-03 993 (no mark)
964-116-028-53 993 TT & 964 3.6TT (red) & GT3 mk2
964-116-028-91 964 3.3TT
964-116-028-90 964 (blue)
996-116-027-51 996 GT3 mk1 & 996TT
and depending on their condition:
950-116-710-04 (1) Operating Shaft
999-113-418-40 (2) Gasket
999-201-339-00 (1) Bushing
999-201-365-00 (1) Bushing
950-116-725-00 (1) Cover
and sometimes...
950-116-086-06 (1) Release Fork
Currently the best pricing in the USA seems to be a toss up between Sunset Imports for genuine OE and Paragon Products for aftermarket OEM ($1295USD) and I think DEVEK is still charging about the same price.
and sometimes...
Last edited by JasonAndreas; 11-19-2005 at 08:01 PM. Reason: updated pressure plate list
Peter & Christer,
I DID search on the archives. I wasn't looking for information about the results of the LWF instalation, or were I should buy it from. I know how it works and the consequences. I just asked for the parts numbers.
Anyhow, thanks all for your help
JasonAndreas answered my question - THANX !
