Difference between a manual and tip engine
Does anyone know the difference between a M64/01 manual engine and a M64/02 tiptronic engine? The literature clearly lists two engines, but a look at the drawings shows no differences. There is a difference in the wiring harnesses, but I would assume that it has more to do with the hookups to the transmission than the engine. Can someone enlighten me????
The throttle pot on a Tip goes only to the Tip control unit . The motor ECU has
the normal idle /WOT switches .Just put the motor in !!
Geoff
Geoff
obviously the flywheel is different and the wiring harness is different because of the backup lights
manual harnness has a wire to the trans, tip has a wire to the shifter console
