Optimoly
Every where I turn in the spec book it calls for optimoly grease. Where do you get it? I am sure that the trinity of parts does not carry it. Is there a substitute? Will any high temp moly grease do?
Technical Guru
I bought a tube of Optimoly HT from Sunset Imports (around $8ish) so any Porsche dealer can order it, part #000-043-004-00. Your local auto supply shop can also probably order it just make sure they order the right lube, I think there are 30-40 different types of Optimoly.
Technical Guru
Originally Posted by mbrouder
I've tried two dealers with no luck. Is there anywhere online that carries it?
