964 Forum 1989-1994
Did my Freudenberg DMF just bite the dust?????
Old Feb 1, 2003 | 10:43 PM
Bill Wagner's Avatar
Bill Wagner
Angry Did my Freudenberg DMF just bite the dust?????
My 964 (a '91 C4 with 31.5K miles on it) was behaving great all day. To close out the day I decided to stop and get some groceries. After doing so, I got back into the car and started off. I noticed what sounds like a drive line vibration (remember, it's a C4) and just blew it off. Well the noise got worse quickly, and I noticed that when I release the clutch I'm getting a thudding sound. If you can imagine releasing the clutch about 2/3rds way and then sliding your foot immediately off the clutch allowing it to "pop the clutch" it's sort of like that type of thud. If I put my foot on the gas suddenly I'm getting a lot of driveline noise...like a vibration.
This isn't the sound that I've typically heard of when others have told me about Freudenberg DMF failures, and the noise isn't severe yet. If I was completely unaware of the DMF problems with Freudenbergs, I'd almost think one of the engine mounts or maybe a support somewhere in the driveline had failed.
What do you guys think???
<img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Old Feb 1, 2003 | 11:28 PM
Ragin' Bajan's Avatar
Ragin' Bajan
Post
I think you're in for some expensive repairs <img border="0" alt="[crying]" title="" src="graemlins/crying.gif" /> . Your description sounds like what happened to mine when it went. Aka, the $ound of money.
Old Feb 2, 2003 | 06:14 AM
Adrian's Avatar
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Post
Dear Bill,
Sounds like a DMF failure to me. The thudding is the two masses working against each other rather than together. As I said in my earlier post, if the silicon damping fluid leaks out you are going to get stranded. This is not common but I know of two cases where this happens. Takes the clutch out very nicely and it stinks,
Ciao,
Adrian
911C4
Old Feb 2, 2003 | 09:49 AM
marc 1xx1's Avatar
marc 1xx1
Post
Sounds like your in for a new lighter weight single mass flywheel conversion.
I remember the sound well.
marc
