Ignition troubles
I have a 1990 C4. Having problems with the ignition. Complete ignition failure under full load at about 4k revs and above. I have discovered one thing. If i unplug either one of the ignition modules, it runs perfectly. Without a glitch. I'm wondering also if the distributor drive belt may have jumped a tooth. I've checked the alignment and they are very slightly off of the factory marks.
Has anyone come across this before? Any ideas would be great.
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
I doubt the distributor belt has jumped a tooth. If you suspect a problem inspect the belt and replace it if in doubt.
I suspect you have already found your problem, a failed ignition coil.
Ciao,
Adrian
911C4
Ciao,
Adrian
911C4
