newbie pad question
newbie pad question
Do i need to replace pad sensors when replacing pads? (do they wear out?)
What anti squeal stuff should i ask for in a uk shop?
cheers stu
cheers stu
Burgled
you can cut them and twist/solder the ends together if you dont want the sensors. May or may not be a good idea depending on if you check them manually occasionally. The "hats" pads that are stock with them cost about $4-5 each. Search and you can see what others have used
IHI KING!
I don't use the "hats". I use an anti-squeel compound instead. The brand I use is Permatex (no affiliation). It comes in a spray can. One can lasts a very long time (10 years+). I'm not sure if this is available in the UK but I'm sure there is a similar product. I find it to be a lot cheaper than buying the factory's "hats" and also it makes the pads easier to slide out of the calipers when it comes time to replace them.
http://www.permatex.com/auto/autouc....&item_no=80729
Super Duper Moderator
Like Rob, I ditched the hats as it makes changing pads a pest.
I used high temp lithium grease on the back of the pads and it works well.
Marc
Marc
Hiya stuart1997
"Do i need to replace pad sensors when replacing pads?"
If the old sensors are not broken , you can use them again .
I like the sensors , they are nice to have .
(do they wear out?)"
They get ground down and broken when the pads get thin .
When the sensor gets ground down it comes apart and the comeing apart turns on the dash light .
Cheers for all the replies
I`ll get some new sensors as well as my front pads look pretty thin.
Thanks for the offer Pesty will pm you when i get the bits-will have to be a dry day as my garage is tiny!
