Bumperette or clears?
Originally Posted by JasonAndreas
Darryl,
I was able to remove my driver's (left) side bumperette mounting piece by simply pulling the plastic bumper slightly and wiggling it out (i was in a hurry so I cut the other side). Its a little more work but you could loosen the bumper bolts, all you need is about an 1/8" extra space to easily remove the mounting pieces. In any case, cutting the mounting pieces does not have to be a permanent solution as they are sold separately by PCNA #964-505-085-00.
