There is a bolt on one side and a red plastic pull-plunger on the other, the seatback can be released by removing the bolt and swinging that side out and pull the seatback away.
I'm not sure a cabriolet is the same as a coupe back there, but look if the carpet that's on the back of the seatback goes under another panel...if so, you'll have to release the extra carpet that goes underneath anything as I'm sure it will be screwed or glued in to secure it.
