Cabrio leaks- ugh
Cabrio leaks- ugh
Well, we had a great ride yesterday. The morning started off cloudy, but no wetness on the roads. We had 21 cars show up, including 2 928s, a 924, and 4 Boxters; the rest were 911s. Lots of SCs, Carreras, and 993 or later; mine was the only 964 in the group.
During lunch, the sky opened, and let go of some excess moisture; and proceeded to get worse. All this moisture helped point out that my top leaks; right above the wing windows- both sides. Anyone ever done anything about these? I don't usually drive the car in the rain, but I don't want to worry about leaks if I get caught in the rain.
I should also replace the seals along the vertical side of the movable windows, as they leak air; no real rain coming in that way, but it's not a tight fit.
Anyone? Thanks in advance. (btw- I did a search without much success.)
My '90 C2 Cabrio leaks in the same exact spots that yours does. I find nothing wrong with the seals. Everything looks fine.
I am not too concerned about it. It seems to leak mostly when the car isn't moving, a small drip, drip. Maybe the inside of the car is pressurized slightly when moving which may stop the leak.
Professor of Pending Projects
I made the mistake of replacing the seal/weatherstrip around the front... made no difference... small drops of water will get in from time to time... The manual even says that it water could get in and that it is normal...
If someone has fixed the leaks please chime in!!
In response to a tip from another Rennlister, a while back I bought some "Raggtopp" spray and applied it to the top of my '91 C2 cab. It made my top waterproof again (water beads on it), and just about eliminated the instances in which I got the leaks that you described (of course, no convertible is completely waterproof). I bought my Raggtopp from http://www.autogeek.net/rafaca.htmls, but I believe it's available from lots of places. You just wash the car (including the top), spray it on the fabric, rub it in with your hand or a cotton rag, and let it dry. Unlike the Porsche factory convertible top conditioner, Raggtopp won't damage your paint. As an unexpected bonus, it made my somewhat faded top a little darker black. (Of course, no affiliation with Raggtopp or autogeek.net, just a satisfied customer).
Regards,
John
Regards,
John
I had to read it again... so it is leaking through the fabric?? If so, the product mentioned by JJJMCD or the factory stuff should do the trick.
I don't think it's the fabric- more likely the seals on top of the fixed wing windows and slightly from the movable windows. Then again, the conditioner can't hurt....
Burgled
Hey Geoff
Your ride sounded like fun! You couldnt get going fast enuf to get a perfect 360
You will be amazed at how good the Ragtop conditioner does! Its like you waxed your fabric! (nope dont work for them or own stock in the company) I have never noticed any drips even in hard rains on mine. I checked under the rear mats this weekend and that area was dry. You may want to check under the mats on yours. Seems to be where the water ends up.
