water in my oil? But it's a 911...
So I was changing the oil in preparation for a valve adjustment in my C2. I first drained the oil from the crankcase, no problems, and only a lttle bit of "hair' on the magnet. When I began to drain at the thermostat, just in front of the right rear wheel, the first thing that came out was an ounce or two of water!!!??? then a little pale frothy mustardy looking stuff came out. Any idea what gives...I'm using Mobil 1 synthetic 15w/50 and this oil only has about about 4000 miles on it...
-CKKrause
-CKKrause
Lack of mileage, do some more miles to get it warm properly. Condensation is a product of cool air condensing on the engine surfaces, get it hot enough and it evaporates. you usually find it in the colder of the oil pipes as well.
Typical signs in Normal 4 pots are shown on the oil filler cap.
Change oil, and use it more often/longer periods.
Kevin.
Kevin.
I've always heard that its good to run the oil temperature up to at least 220 degrees F once in a while to boil off all the water in the oil. If you're one of those guys that tends to keep things under 210 all the time, that could be what's causing all that condensation.
Don
Don
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Don Ahn:
<strong>If you're one of those guys that tends to keep things under 210 all the time, that could be what's causing all that condensation.
Don</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">My car keeps itself cool, I don't have anything to do with it. Well, short of driving around with the front boarded up so no air flows to the oilcooler. But that would be silly. Wouldn't it?
Thanks for your comments... By the way, the car is my daily driver and often gets hot enough to get the oil cooler fan going...The bottom line is that this doesn't seem to be a big deal and the best advice is to drive it more...not bad!
-CKKrause
-CKKrause
