"!" light w/ manual map light opp, door lock led ?
The dome light, or map light, has stoped working. When I manually turn it on the ! light lights up . When I turn the map light off the ! light goes out . The door switches don't opperate the dome map light either . (I have checked the bulb and fuse)
Also the alarm LED's are not flashing they stay on very dim when you lock the the doors while you are in the car running . The alarm seems to still work, If I lock the car with the door half latched , then try and open the door the horn starts sounding .
