clock connector, large.
Try both of these links from Pelican Parts. One of them should have the answer.
<a href="http://www.pelicanparts.com/techarticles/mult_gauge_face/mult_gauge_face2.htm" target="_blank">Old Gauges</a>
<a href="http://www.pelicanparts.com/techarticles/964_gauge/964_white_gauge_faces.htm" target="_blank">Newer Gauges</a>
If not, you will need to post a pic of your dilemma or more detail.
Good luck!
Good luck!
So you opened the round large connector and all the pins slipped out, hm? Happened to me before.
You need the schematics out of the 964 factory workshop manual. That will tell you the wire colors and the acording pin numbers. Here is what I see (on a hardly readable copy) No garanties!!:
Pin 1 0.50 GR/BL
Pin 2 0.75 BR
Pin 3 n.c.
Pin 4 0.75 RE
Pin 5 0.5 BL/WT
Pin 6 0.5 WT/GN
Pin 7 0.5 GN/BR
Pin 8 n.c.
Pin 9 n.c.
Pin 10 n.c.
Pin 11 0.5 GN/YE
Pin 12 0.5 BL
Pin 13 0.5 YE/RD
Pin 14 0.5 GR/YE
Pin 15 0.75 OR
Ingo
Pin 1 0.50 GR/BL
Pin 2 0.75 BR
Pin 3 n.c.
Pin 4 0.75 RE
Pin 5 0.5 BL/WT
Pin 6 0.5 WT/GN
Pin 7 0.5 GN/BR
Pin 8 n.c.
Pin 9 n.c.
Pin 10 n.c.
Pin 11 0.5 GN/YE
Pin 12 0.5 BL
Pin 13 0.5 YE/RD
Pin 14 0.5 GR/YE
Pin 15 0.75 OR
Ingo
