Clock Spring and New Steering Wheel Question
Is the clock spring something that is steering wheel dependent? That is, if I get a new steering wheel, will I need to replace the clock spring too?
When I had my steering wheel off to replace the switch cluster the clock spring assembly wasn't part of the wheel itself. If you plopping a Momo or something on there without an airbag then you won't need the clock spring... Putting a different airbag wheel on and you might, it will depend on what has changed.
Technical Guru
