Need Help!!!!!
I need some help. I am replacing my engine mounts and I can't move the 19mm bolts on either side. My socket won't work and my wrench will not work. Any advice would be great. Other than not being able to get the bolts loose it is pretty simple. The instruction from p-car.com are very helpful.
TIA
Chris
TIA
Chris
Technical Guru
Have you placed a hydraulic jack under the engine and lifted it a tiny bit to take the tension off the engine mount bolts? The only other suggestion I can think of is to use as much mechanical advantage as you can (I use a 3' breaker bar).
