Turn signal stays lit with ignition off
I've noticed that when I shut the car off with the turn signal on, the circuit stays lit. It is not flashing but on solid. Does this both sides.
Would you guess that I have a flasher or relay going bad or is this normal?
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
This is normal. It is called street parking lights. A European requirement.
The rear light on the same side should also be on.
Ciao,
Adrian.
Ciao,
Adrian.
Yes, Adrians correct. It should only happen with you stop the car with the lights & indicator on. The corresponding front side light & rear light should stay lit.
