Removing front speakers
I'm planning on replacing my speakers with better ones. Do the front speakers just pull out, or do I need to remove the door panel to remove them?
Andy-
You have to pull the speaker covers off and you should see 4 screws securing the speakers to the door panels. Unscrew and disconnect speaker wires.
--CKKrause
--CKKrause
But....you may also have tweeters in the upper door panel. Those come out easy too. Its getting new speakers to fit perfectly that can be a pain.
Now, if you go through that trouble, you will want to replace the crossovers which are hidden in a compartment inside the armrest.
Check out this site for some really good technical info....plus the guy makes some killer subs too.
<a href="http://www.caraudioinnovations.com/" target="_blank">http://www.caraudioinnovations.com/</a>
BGL
BGL
Thanks for your help everyone! I managed to change my front speakers today! The cover to the Tweeters does unswrew, but the Mid Range does not. Luckliy, I managed to carefully remove the covers with the help of a screw driver, mount my new Infinity 552i's (13cm) & re-use the stock covers!
It sounds much better now. With 13 years of use, the origional ones had virtually disintigrated!
Andy
Andy
