Help! - Oil pressure drops to zero at idle
#31
Originally Posted by Graham L
mine started out at £3500, then came the new tinware, then the valves, then the clutch...etc. etc. ended up at £7k, then £280 for the post rebuild service...
#32
hi,
you have me worried !!!
what is the normal level that the oil pressure gauge should be reading on a fully warmed engine......mine reads around the 1 bar level at idle.... 5 bar under full acceleration.....fully warmed?
steve
steve
#33
When oil is cold at start up ambient temp +14 degrees.
800rpm................2 to 3 Bar Indicated
2000rpm +............4 to 5 Bar Indicated
When oil is hot (thermostat fully open running 0-40 Mobil 1)
800rpm.............1.5 to 1.7 Bar Indicated
2000rpm +..........4 to 4.5 Bar Indicated
Above 1500rpm oil pressure never reads below 3.5 Bar
I hope this helps by way of comparrison. (74000 miles original build C2 run on Mobil 1 all its life never missed a service).
I know this engine seemed strong in terms of bhp and oil px when compared to many of the 26 cars I saw before I bought this one. What do other members cars indicate?
#34
Steve - don't worry too much. There was a thread on this quite a while ago, and pressures do seem to vary quite a bit at idle between cars. Mine is about 1.2 on a warm engine - and it's been like that for the 4 years since I've owned the car (and it had a top end rebuild just before I bought it).
#35
Hi,
Thanks for the info
Planning an oil and filter change before the winter....question is what grade of oil to use.....this will be the first change since i got the car......i live in Scotland so the temps can get pretty cold here during the winter months......any ideas?
10w40?
15w40?
Fully synth or semi ?
Thinking of Magnatec 10w40
steve
Thanks for the info
10w40?
15w40?
steve
