Brake/clutch bleed problem
I am having a problem with my fluid reservoir. I am using a power bleeder, but I cannot get it to build any pressure. I hooked it up to my Mercedes and it worked just fine, so I am guessing that there is something wrong on the Porsche end. Is it possible for the reservoir to have a small crack or something? I don't see any evidence of fluid leaking in the trunk area. I am tightening the cap as tight as it will go. What am I doing wrong?
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Thanks, I got it done. I was amazed at how much black goopy fluid came out until I saw the ATE blue. I was also able to verify that the overflow does indeed work when I removed the clamp before de-pressurizing the power bleeder
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
If you want more junk out and bleed the ABS, turn on your ignition while the power bleeder is hooked up.
This will flow new clean fluid through the ABS pump. FWIW.
This will flow new clean fluid through the ABS pump. FWIW.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
To activate the ABS return pump in the ABS only systems you need the Bosch Hammer.
Ciao,
Adrian.
