C4 PDAS/ABS Update
Lead Rennlist
Technical Advisor
Lifetime Member
Ciao,
Adrian
911C4
Just wanted to say thanks for continuing to post on this. For me and others who do not possess the in depth technical knowledge you and others have, this forum is a great place to learn and validate what we are being told by our mechanics
Thanks again,
Andy
Lead Rennlist
Technical Advisor
Lifetime Member
I know you have the maintenance manual. Go to the section on brakes. You will see that it takes 25 pushes of the pedals to remove the pressure. This is the procedure to bleed the pressure off the system. If the hydraulic pump does not crank up (under normal intermittant operation conditions) you will have no brake pressure or an ever reducing brake pressure every time you push the pedal. I can tell you from some testing I did some time ago that it takes around 10 pushes of the pedal and you is in deep trouble if the pump does not crank up. "NO BRAKES" and warning lights on and warn horn blasting away. Three or four pushes will bring on the warn light if you are stopped.
No pump running and you have no brakes, after quite a short time,
Ciao,
Adrian
911C4
PS: The 80 bar accumulator is insufficient to power the entire system of a C4 which you must know under normal operation is fully open.
Lead Rennlist
Technical Advisor
Lifetime Member
Once the system has been returned to its correct configuration we will actually then try to work out what has failed. Obviously the PO had a problem and the fault could not be located or was not even looked at, but the system was disabled and the C4 sold on.
When people do this type of thing it does make things very difficult and some owner patience is required. These things are not in the manual. As I have said beofre, this is now the third C4 I have been asked to assist with that has had some form of system disabling carried out,
Ciao,
Adrian
911C4
Lead Rennlist
Technical Advisor
Lifetime Member
It is too late when your brake pedal goes rock hard (no pressure) and you plough into the rear of somebody else.
There are certification requirements when new and there is reality 13 years down the track.
I also recommend every C4 owner reads the owners manual and see what the instructions are when the brake warn light comes on. If the pump fails this light will come on very quickly and you can check this very easily by pumping the brake pedal whilst stopped.
This is pure experience talking here because this was the very first fault that ever happened to me on my C4. Nobody in 1999 could help me, via bulletin boards or the rennlist mail lists. I had to go find out myself. This I did and this is what I share today.
Ciao,
Adrian
911C4
Do I understand correctly that normal mode of operation then is that at an idle if you step on the brake pedal 3-4 times the warn light should blimp on then go back off? And those warn lights should be the "brake" light and the "4 wheel drive looking" light. Correct??
Bob
I have a C4, but, am not willing to purposely test your theory with mine
I know for sure that there is braking power upon power failure (at least enough to stop) because I had an issue of stalling a while back and stopped many times after the engine died. Now I would not want to be traveling at 100 MPH and test this theory, but, from a reasonable cruising speed you will certainly be able to stop.
I think if you look at Adrian's post again. He is not saying there are NO brakes if power is lost. He is saying that you only have so many pushes of the brakes before there is no more pressure. Obviously, if the power were to be lost then you would press the brakes just once to stop yourself and that's all that would be needed.
Not trying to take sides. I think you are both saying the same thing and don't realize it.
Kris
89 C4
I was quoted USD$6,000.00 for the repairs. Based on this I went back to the seller and 'convinced' him that it would be in his best interest to split this cost with me and was given a USD$3,000.00 rebate. And the repairs I was quoted for wouldn't have fixed the problem as the mechanics diagnosis of failure was based on swapping over a PDAS/ABS control unit from a 993 onto my 964. Back when I was in never never land it seemed plausible, I have since learnt among other things that the systems are different and not interchangeable. Which is the crux of forums like this. You save money yes, but you also learn and that to me is priceless.
cheers,
Kris
89 C4
My owners manual states quite clearly that in the event of an ABS/PDAS failure the brakes will still work... they just won't work with ABS, and the AWD system won't be working properly either. The section you are referring to in the manual is about BLEEDING the brakes. If the brake lines aren't open like they would be in the bleeding process the events you're describing could not and would not occur. If on the other hand someone is driving around with their brake fluid leaking out like it would be in the bleeding process, I think they probably have MORE to worry about than their pumps!
Borion:
Your test is interesting, but probably unsafe UNLESS someone could do it at VERY low speeds (like 10mph) on a large parking lot with no obstructions. If I cut my power completely, the only way to totally do it without fooling with the electrical system itself would be to turn the power completely off. Since my car has a steering wheel lock, I would really have no steering. This would not be the case if the pump is not supplied electricity when the key is in accessory mode, but I don't know if the pump is receiving electricity at this point or not. If I ever find a place that big where I could perform this test of yours I will do it, but (no offense) I'm not going out to hunt for such a location. I already KNOW the brakes won't quit.
CHEERS
Bill Wagner
Lead Rennlist
Technical Advisor
Lifetime Member
Now things are yet again getting out of hand with people taking my comments literally, without reading the context of the thread. The context of my statements was that Kris mechanic told him the pump had failed. I said Kris had been driving around for some time so this is not possible. Without the hydraulic pump you have no brakes. Now we have progressed to as soon as the pump fails, turning power of the car in a car park.
If the pump fails the first thing that happens is the brake pressure warn light will come on (assuming it has not been disabled). When this light comes on you have approximately 10 full brake applications left. If you continue driving after these ten applications of brakes and the pump does not crank up to repressurise the system, "you is in trouble". Want to try it, I do not recommend it.
Certification of these systems requires the auto to be able to stop after a failure of the hydraulic pump. The pre-charged accumulator (set at 80 bar) performs this task. Therefore you will have brakes so you can stop. There is no requirement in the law that you can continue driving around with brake warning lights on and ignore them.
HOWEVER!!!!, how many C4 owners have actually pressure checked their system and how many actually know if the accumulator is still holding 80 bar. How many are actually serviceable. How many are sitting at 10 bar. A serviceable pump will cover this up.
So lets get back on track and stop this literal nonsense. I have grave concerns of people driving around with warning lights and they are warning lights for a very good reason.
After your hydraulic pump fails in a C4 you "Should" have sufficient pressure provided by the accumulator to stop. If you decide to continue driving and your pump has actually failed, (very rare failure) then you are going to have a hard pedal real quick. The accumulator cannot keep the system pressure charged. It was never designed to do so. As I said you can see this very quickly when stopped. Pump your pedal and see when the brake pressure light comes on. If you want to believe you can drive around with the brake warn light on all day, please let me know when you are driving so I can make sure you are not behind me.
Resuming normal channels. Pump failed, get a tow truck,
Ciao,
Adrian
911C4
PS: The power steering is "power assist", ever tried driving around with a broken pump belt. Exactly the same principle.
Lead Rennlist
Technical Advisor
Lifetime Member
Ciao,
Adrian
911C4
PS: ABS relay has been jumpered and to no affect.
If the pump fails the brakes regress to being like old simple hydraulic brakes, and they stay that way. It's what we in engineering acll a failsafe mode. If Porsche didn't put this in they would have been sued at least 100 times in this country for at leats $50M a pop. Their reputation would be that they build unsafe cars.
The brakes worrk with the pump deactivated. They won't work very well, but they will work.
I don't have a C4 so I can't do the AWD test. Unless of course someone wants to give me their car :-).
Bob
