Just got my Baby Back Again
I just had a lot of work done on my 1990 C4 cab and I have a question. They replaced my slave, flywheel, starter, power window motor and all of the bearings relating to the clutch. They also rebled the clutch system. My car now feels as though the transmission isn't fully dissengaging when the clutch is pressed. It is also much harder to get into 1st gear than it used to be.
Is this just normal for having this work done or should I call the shop again?
Peter
Peter
Hmmmmmm, hard to tell, but if the clutch is truly NOT disengaging all the way...the bleeding of the clutch system is suspect.
Have them bleed your braking system as well, being that it all comes from the same reservoir.
